Hi, I recently found this used 128MB Radeon 9100 for a good price and decided to flash it for Mac:
For flashing, as I don't have a PC, I use a TLL866 programmer and I have a few 25P10 EEPROMs to replace the original 25P05, which I have used with other graphics cards (7000PCI, Radeon 9200,...)
I should say I've run the tests on a GE and a QS. The GE already has a flashed Radeon 8500 64MB installed, which works perfectly.
I used the ROM I found here for 9100 :
macelite
I used a ROM modified by @joevt, I don't know if he's the same one from this forum. It's configured for 250/250 MHz (I don't know if the chips in this graphics card would support the speed of the 8500 ROM).
Many years ago I flashed another 9100, I don't remember if it was 128MB or 64MB, but 64MB was useful. I thought only 64MB was working, but booting into Sorbet Leopard shows me 128MB. I've run xbench and the graphics card seems to work without any problems:
Is it normal for it to recognize 128MB? I don't know the brand of the graphics card.
But under OS 9, it stays on the desktop without loading the icons or the top bar, both on the GE and the QS. I've tried it several times. And as I said, the GE already uses a 64MB 8500 without any problems:
What could be the cause of this issue under OS9? Could it work with the original 8500 ROM?
Thanks.
macelite
Thanks.
