After my misfortune with the Quicksilver G4 (which may still see life) I have been given a second chance at an upgrade with this haul, along with one of my all-time favourite machines.
iMac G3/400 "Ruby". Absolutely amazing. It belonged to a school where it served as the teacher's personal machine for presentations and slideshows, probably used not all that frequently. Most of the damage is to the casing, the base needs a realignment and the upper case just needs a good polish up. Otherwise it's pristine. Was running Mac OS X 10.4.7, but I reinstalled Mac OS 9.2.2 mostly for the nostalgia factor.
eMac G4/??? x2. These machines are a mystery. One is missing the drive door and the other is missing the sticker from the drive door. We'll assume they're 700mhz for now until any other spec is confirmed. They were used as student machines until their building caught fire a while back. Both were written off as "fire damaged" but a safety inspection has found they are both perfectly operational without any warping or cracking of the cases. They look pristine. Will find out more when I pick them up.
EDIT: Just did an inspection of the G3, the speakers are free of pin damage and the optical drive still runs perfectly. Hard disk is silent and quick to access. It's practically new.
Perhaps for one of the eMacs, provided the specs are within range, i'll load it up with OS X Leopard. Even if it isn't, I can still do it with a firmware trick. As usual only just for fun, but as with all my fun projects, if it works well enough, it stays...
