SE/30 SCSI Not Detected
I have an SE/30 that works great, except I can't get it to detect the internal SCSI hard drive.
Booting from a 7.0.1 Disk Tools disk, I can run HD SC Setup but it tells me that no suitable SCSI devices were found.
The drive spins up fine, but the activity light never blinks. I tried pulling a working 42 S drive from a Classic II, but it does the exact same thing as the 80 S originally in the SE/30.
I thought the issue might be the caps, so I did a full recap of the logic board using the following:
1x 1uf 50v Radial Electrolytic
1x 220uf 16v Axial Electrolytic
1x 470uf 50v Axial Electrolytic
10x 47uf 16v Radial Non-Polarized Electrolytic
I used SMD291 in removing the SMD Electrolytic caps and in replacing them.
I also replaced the PRAM battery.
Once everything was back together, I flipped the switch and... exact same issue. Except the sound works now. I forgot it was even broken.
So I'm pretty much back in the same spot. There's always a chance I did something wrong, since this is the first recap I've ever done.
At what points could the issue be?
Good thing you recapped that logic board. It had to be done anyway. Since you're new around here (and by the way, welcome!), I take the opportunity to warn you about the Maxell "Bomb". Some 3.6V ½ AA batteries explode and boards which suffered from them are usually beyond repair. So, if you haven't already done so, I advise you to remove the battery now. The Mac will run fine without it. You can buy a replacement if you want.
Back to the SCSI issue... Here are a few suggestions:
- Wash the board if you haven't already done so. Some old cap goo might still be bridging contacts. I usually wash my boards before I recap them (after I remove the old, perished caps), but you should still be able to wash it after you put the new ones on. Take a large bucket, fill it with hot tap water, add some washing-up liquid, mix and immerge your board. Get an old toothbrush and gently scrub the board. After that, rinse it with clear water and dry it immediately (otherwise it'll rust!). I use a hair dryer for that. Dry it really well. You don't want to fry any components after you put it back in the /30.
- Have you tried a different SCSI cable? Did you keep the cable from the Classic II? Sometimes cables die or aren't the appropriate ones, I've seen that happen before.
- I would have told you to use another piece of software (for example Lido. It works a lot better than Apple's HD Setup, especially on non Apple drives), but since your known working drive doesn't work in the /30, it's probably not a formatting issue.
If none of the above work, then you probably have a bad SCSI chip or blown fuse... This can happen if, for example, the previous owner plugged in a parallel device to the SCSI port. You can still buy NOS ones without cannibalising a dead Mac, I think...
Edit: Yes, you can still buy ones on ebay...
https://www.ebay.com/itm/QTY-1x-NCR-53C80-609-3400257-SCSI-Interface-Controller-PLCC-/140919602890?_trksid=p2349526.m4383.l4275.c4
https://www.ebay.com/itm/1pcs-AM53C80AJC-BULK-AM53C80-PLCC44-AMD/263277308606?hash=item3d4c8ceabe:g:7bUAAOSw7z1Z7gzf
Check the term-power fuse next to the SCSI port first. It can blow easily when devices are attached or detached while the machine is running.
I had a board that would only see SCSI devices on the internal connector when a terminator was plugged into the external port. This resulted from a blown fuse as well.
the 3 caps leak really bad by the molex connector. More times than not, it takes out a connection or two to the SCSI IC. Known problem. Youll need to buzz them out against the schematic, and run patch-wires.
It had a Tandiran battery in it when I got it (looks like it's dated 1990), and I replaced it with a Tenergy battery (the only thing I could find at Fry's, almost missed it too. Hopefully it's not as bad as the Maxell battery, but I was considering some way to get it further away from the board or protect it.
I sprayed it pretty well with electrical contact cleaner spray, I'm not sure if that quite did the job though. Maybe I'll try fully washing it.
I went back and pulled the SCSI cable from the Classic II today, didn't solve the problem unfortunately.
Yep, I tried Lido, it doesn't give any errors but it doesn't detect any drives.
Hmm, I might try that if I don't have luck with anything else. I'll probably try to order a rework station first, probably a bit easier than my heat gun.
The fuses are F1, F2, and F3 right? They aren't like any fuses I've ever seen. I checked them with a multimeter in resistance mode (my multimeter with continuity mode needs new batteries) and all the fuses seemed fine.
Hmm. That's an idea. I'll have to see if I can make sense of these schematics I found online.
So I gave a good washing, but it didn't seem to do any good. Actually I thought I ruined it at first, since I was getting simasimac when I booted it up, but then I found some unseated RAM when I opened it back up (and then more the second time I opened it back up).
I ordered a replacement SCSI chip that should be here by the end of the week, just in case that's the issue.
Can anyone help me a little with testing connections against the schematic? I've looked over the BOMARC and the Apple versions of the schematic and tried testing a few points, but I guess I'm having trouble making sense of the schematics.
