This obviously isn't a 'new' topic. My previous soldering iron (and I...) ruined the pads (on C12) here. I'm looking for any advice specifically on that. Then I have to recap it all (which I've gotten better at since that botched operation), and replace a few of the parts. I might have to de-socket the video card socket (I don't know if that's how you say that), because part of a toothpick may be stuck in there - though it might not affect the connection, who knows.
Anyway, any advice broadly and then more specifically on the pads - because I was going to try to do that tonight or tomorrow. The previous suggestions I've gotten were just to solder up to the trace, which is more or less what I'd planned to do. But I'm not that proficient, so this is going to heavily involve the flux I got and basically scraping solder out into the pad. How exactly do you connect it to the trace? Up to or on top of? (because there's some sort of laminant on top of the trace itself?) In other words, does it connect laterally or vertically?
