Hi, I have a SE/30 saved from major caps leakage, apart from recap had to repair some chips and vias to restore video. Still there's a sound issue, you cant hear it at all and whenever the programs call the sound it crashes. For example in Disk Copy it happens when I keep "Confirm before copying" option on (it should beep on normal Mac), it's fine when it's disabled.
So what seems obvious to me is check the connection between ASC and Sony sound chips. I have a schematic for the SE/30 logicboard, but the problem is I can't really figure out orientation of the pins on ASC and Sony sound chips. How can you tell which one is pin 1 and the others ?
