C1, C7, C12, C13 are 47uf 16v, C11 is a 220uf at 16v. These capacitors form a supply filter network on the 5V source. (If bad, will cause simasaimac condition. if noise floor and glitches exceed safe limits, will fry logic ICs)
C10 is a 47uf at 16V. This in conjunction with L11 and C25 forms a tuned pi filter network on the 12V rail. (will cause noisy audio, floppy disk drive issues)
C2 470uf at 16v is the audio power supply filter capacitor. (will cause noisy and weak/distorted audio)
C9 is 47uf at 16v, This forms the -12v supply filter network. (will cause noisy audio in speaker only, -12v is used in the op-amp, and floppy disk drive issues)
C8 is same as C9, forms the -5v filter network. (will cause serial communication or other issues.)
C4 is 47uf and the Right output DC blocking capacitor. (will cause weak/distorted or missing audio in right channel) (If shorted, will drive DC into your headphones/speakers, and that... is.... BAD)
C3 is 47uf and the Left output DC blocking capacitor. (will cause weak/distorted or missing audio in left channel)
C5 is 47uf and is the output reference voltage filter capacitor. (will cause missing audio)
C6 is the Right channel DAC output filter capacitor. 1uf. (will cause noisy or missing audio)
Funny thing is, C24 is the same capacitor for the left channel, BUT its a different value! 0.1uf. Maybe a design error?
Also, C3 and C4 are INLINE CAPACITORS AND ARE NOT GROUNDED!!!!!!!!! These are in the audio circuitry as i mentioned above. Ground these, and you will lose audio for sure.
Anyway, there you go.
