SCSI Yamaha CDR400t-NB CD-R drive, Mac OS 8.1 compatible?
Snial
Moderator
Staff member
68000
Hi folks,
I found a SCSI Yamaha CDR400t-NB CD-R drive at my Dad's house, so I thought I'd 'rescue' it ;-) ! It was loose inside the SCSI enclosure so I spent a bit of time drilling some holes in the bottom so I could fix it in place. When I hooked it up to my PowerBook 1400c/166 under Mac OS 8.1 (with the Apple CD-ROM extension) it doesn't seem to recognise any CD inside even though Drive Setup sees it as a SCSI CD-ROM.
The expansion bay CD-ROM worked. I guess the SCSI cable & termination is basically OK, because otherwise it wouldn't have identified the drive. Do those drives need a special driver? Of course, the drive itself might not be working properly, I didn't hear the CD spin-up. I'm not holding out much hope that the PB1400 is fast enough to write to a CD-R, though that would be an amazing bonus if I got it to work and it did!
Any ideas?
First question: are we sure th f drive actually can read discs? A hardware failure is very possible if the drive itself indeed shows up in drive setup. I’d also check Apple System Profiler and see what it says about the drive.
I don't know. I don't even know why I have a 4x SCSI CD-R drive. It doesn't come from my HP 715 PA-RISC workstation; and although I had a 90's or early 00's PC desktop given to me in the late 00's, I think it had IDE only.
Agreed. I've never seen it working anyway, so it's a very real possibility.
I wonder if somehow, even if a disc doesn't mount, it'll play a music CD via the Apple CD player. It doesn't need to read much data then, just know it's an audio CD and play audio out the headphone socket.
I haven't tried any of these things yet, so I'll try and do that next.
A lot of versions of the CD-ROM extension would ignore CD-ROM drives that didn't return an APPLE COMPUTER INC ID string, similar to what unpatched HD SC Setup does with hard drives. I ran into that in MAME until I added the ID. Also, the Apple CD drives used proprietary audio playback commands because they pre-dated the SCSI MMC standard that made the now-standard commands exist. So audio playback is potentially the least likely thing to work.
So, you're saying that I need to add the ID... as a string in a resource in the CD-ROM extension? I suppose the Apple System Profiler has provided the string?
OK, so I can't just see a string, but I have Vendor, Product ID. And yep, the CD audio player didn't like it:
I’d bet the drive will work if you install CDRom Toolkit compatible with MacOS 8.1
OK, I'll have search... Macintosh Garden?
Right, a third party extension should do the trick if the drive itself is OK.
OK, I'll try these things.
I mean you can try FBW CD Toolkit and all that. I honestly have had the best luck with late-release Apple CD/DVD driver extension. I have two non-Apple CD and DVD drives in my PT Pro and it drives them just fine.
If it’s the silver grey external Yamaha drive it’s a bitch to make it work… i gave up years and years ago.
it had proprietary drivers and I believe was primarily made for pc. Also it was used in the music industry so who knows…. I remember ditching it for one of the Plextors
Looks like FWB CD-ROM ToolKit 4.0 is what you need.​
Thanks for the advice, however, FWB CD-ROM Toolkit 4.0 doesn't seem to work. The Mac boots up OK with the extension on, but the application crashes with a type 3 error. I increased the application memory size to 2MB from 500K, but it still crashed immediately with a Type 3.
My go-to in this case is to try and use the Apple CD/DVD Driver extension that comes with 9.1 or something. That might work. FWB always gives me crazy errors when I have tried it, too.
Lacie made external SCSI burners with Yamaha drives; those shipped with Adaptec Toast, might be worth trying out the Toast extension as well and see if that works.
That’s actually excellent advice - I second that. I remember having the extensions in the “must have” disc with the rest of the tools
OK, and that'll work on Mac OS 8.1?
OK, I'll try that if I can find it on Macintosh Garden.
Thanks for the help, so far!
OK, next update. I tried the CD DVD extension from the Mac OS 9.1 updater. As normal, it was a bit of a trial getting there! I had the Mac OS 9.1 updater on CD, which I can read from the PB1400's internal CD drive. There's a system Tome, which I couldn't read. So, I found Tome Viewer on Macintosh Garden. I'm doing all my proper transfers using a compact flash card between this Mac mini 2012 and the PB1400's PCMCIA drive, so there's extra copying stages!
It's in a later .sit format. I could unpack it using my UnstuffIt, but I couldn't open the .img file it unpacked to. So, then I booted up the PowerMac 9500 on Infinite Mac with Mac OS 8.6. Disk Copy 6.3 was on that, so I was able to mount that .img; then I compressed the application using Compact Pro (the best thing ever) and then BinHex'd it for good measure; copied it to the Compact flash card and uncompressed it onto the PB1400.
Now I could read the Tome. I found the CD/DVD extension; unarchived that and then popped it into my System Folder. The extension worked - I could still read CDs on the internal CD drive. However, the external Yamaha CD-R drive still didn't work.
Next attempt, trying Toast. If that doesn't work, I'm toast ;-) !
