I am going to attempt replacing UG8 on my SE/30. What is the best way to remove SOIC chips like these?
I've done some research and Chip Quick (ChipQuick?) SMD removal solder is a possible way, though the "mess" afterwards is a little concerning - looks like you need to use this stuff sparingly! I have some already on hand I've just never used it.
Another video I saw someone scoring the legs with a utility knife that seemed to work well, but I don't want to damage the board. I do have kapton tape to protect the surrounding area. Link should start at 2:44
I've seen the same done using flush cutters.
Adrian from Adrian's digital basement swapped UF8 between two SE/30s for troubleshooting, and he used hot air station which I don't have. But I didn't quite understand how he soldered the new one back on - also using hot air? I didn't see any cleanup of the old solder or putting on fresh solder which I would want to do. Link should start at 20:14
I was going to use this technique to solder on the new chip - that seems straightforward, I'm still up in the air about least risky way to remove the old chip.
