Hi all,
The keyboard that came with my 'new' Lisa 2/10 is in semi-functional condition. Most of the keys would respond after a couple firm presses, but it was pretty clear that the foam-and-foil discs inside had degraded. I've just finished the painstaking task of replacing all the discs, and I'm pleased to report that every keypress registers as expected. Whew!
With that part done, I'm left with two remaining issues - I'd be grateful for suggestions on either of these:
Issue 1: unpleasant key action
Specifically, most of the keys feel very 'grindy' when depressed, and not all of them want to immediately rise back into position after being pressed. I suspect that I could perhaps improve this by using some key switch lubricant, but I've never done this before. If anyone has a tip or suggestion on the best way to lubricate the keys on this keyboard, I'd be happy to hear it!
Issue 2: cracked plastic case
At some point in its existence, this keyboard seems to have been dropped on one corner. There's a crack running from one corner along the top case, and I'd really like to prevent it from spreading further. How would you suggest doing this? Perhaps some plastic-safe glue applied from the inside? I don't want to cause any more damage with a clumsy repair attempt here...
Thanks in advance for any guidance on these topics!
Huxley
Huxley
