I have a IIci board which apparently had a dead 68030, which was removed leaving a clean pad. I'm trying to figure out what I can use to replace it.
I know the IIci ran at 25 MHz, but for some reason 25 MHz 68030s are expensive on eBay. However, 33 MHz chips seem to be far more plentiful. Will a 33 MHz chip run fine at 25 MHz in the IIci?
This is the part I'm thinking of using: https://www.ebay.com/itm/1pcs-MC68030FE33C-ENHANCED-32-BIT-MICROPROCESSOR/392523139565
