Replacement m6411 iBook Charger
I got a really good deal on a graphite m6411, but I need to find a replacement charger. I can't seem to find the model number of the charger it shipped with, and I don't want to damage anything. What should I be looking for? And is there an aftermarket compatible charger I can buy?
Yes, you'll need an earlier revision M7332 charger with the larger barrel (pic below).  The smaller barrel fits later G3/G4 iBooks, which won't do you any good unless you've got one of those as well.  The picture below (borrowed from "ibook-clamshell.com") shows the size difference.  The one you need is on the right and has a 9.5MM barrel.  The later iBooks used a 7.5MM barrel.
