First time posting here.
After owning iBooks and PowerPCs , I caved and acquired a local Powerbook 145B in pristine condition albeit with a non-functional battery.
In researching all solutions on to make this portable euhm -portable- again thus running of a battery, I might have found another solution than rebuilding batteries.
There are these heated-vest batteries that supply 7.4V DC output and thus can hook up to the DC input where the powersupply normally goes.
This works rather well, only quirk I haven't found one that actually fits in the battery tray.
I currently have one sitting next to the Powerbook and it works perfectly.
This is the one I found to be available to me here in Europe , it's just a few millimeters too thick to slide it into the battery tray.
Also being from Europe my buying options are limited since most of these heated vest things target the US buyers.
Like this one for example
Just wanted to share my find , maybe others may find it usefull.
Amazon.com: Smarkey 7.4v 5000mAh Heated Jacket Battery with Charger Cable Replacement Backup Pack for Hoodies, Vests, Down Coat : Clothing, Shoes & Jewelry
www.amazon.com
