I have a few powerbooks where the CCFL bulb isn't that bright anymore. When taking out the bulb, about 1/2 inch on both sides is black so I guess the bulb has had it's best time.
The inverter board is fine, already recapped, also spare inverter boards give the same result.
I usually buy my parts at Mouser.
Can someone point me to the right bulb or give me a part number ?
I know Apple has different inverters and bulb kits in the service source depending on the panel revision but does it matter that much ?
