I just completed a IIci recap two nights ago. It went well, but the board had seen better days so I wasn't feeling 100% positive about it working straight away.
It actually works and works quite well, but with one weird issue-- it takes 3, sometimes 4 seconds of holding down the power button for it to fire up. This holds true for the rear case button, as well as the keyboard power button. It takes barely a touch on the rear power button for it to turn off. So I think the switch is fine.
I have tried two separate power supplies, washed the board thoroughly and touched up the new caps.
I had to touch up some of the traces on the board as well, but to me this sounds more like a cap issue then a trace issue. Or could a bad trace cause this behavior?
