Hi,
As per my Conquests post, I've built up one "good" Lombard Powerbook G3 from two, which is specced as:
- 333 @ 433Mhz (did this once before, and it's rock solid yet again!), on the 400Mhz DVD-accelerated motherboard
- 384MB RAM/40GB 5400RPM HD
- OK battery, DVD drive
It's come up well, and running 10.4.11 quite nicely - good enough for Safari and Word, which is all it'll be used for by my friend.
The only other thing I need to tackle is to rebuild the PRAM battery, which is completely dead. If there isn't a good PRAM in a Lombard it tends to have some unusual behaviour when you plug it into mains.
I've stripped down one PRAM battery and found 4 x 3V Panasonic cells (Lithium? I can't tell, haven't check the part no yet) which appear to be soldered in parallel. Looking at how they're wired up it will be difficult to replicate this again, as it's hard to solder battery terminals - especially this many!
So I was wondering if there is a substitute single celled PRAM battery I could use, or if anyone has any other suggestions?
Also, I found this on LowEndMac:
Thanks
JB
I can't say it does much.I have resurrected supposedly "dead" PRAM batteries by connecting a Pismo to AC but with the main Li-Ion battery disconnected and the PRAM battery connected for between 24 and 48 hours nonstop, after which time the PRAM battery has been reactivated and recharged, enabling the Pismo to then be booted with the PRAM battery still connected.
Thanks
JB
