Rasterops 364 Colour Card
Hi. I'm bringing my vintage SE/30 back to life after 25 years in the garage. I have a Rasterops 364 card fitted which I know is 640 x 480 but have no idea how to hook up an LCD display to receive the analogue signal. Can anyone point me to some advice? Many thanks.
First of all you need a DA-15 to VGA adapter and preferably one with dip-switches on it. I'm at work now, so I can't give you any model numbers of my ones.
Something like this would be good: https://www.amazon.com/Adapter-DB15-Male-Female-Switches/dp/B0016OC1J2
Next of all is the LCD monitor. These can be hit-and-miss, mostly because LCD monitors have a default frequency of 60MHz and monitors for Macs at the time supported higher frequencies (e.g. 75MHz). Many monitors support other frequencies.
Epson monitors have a good reputation. I have a 1024x768 Eizo monitor that runs adequately for 640x480 as driven by a Supermac Thunder card in my IIfx or from a Performa 475.
On another note, you probably left the PRAM battery inside your SE/30 all this time. I would that out of the SE/30 as soon as possible.
There have been far too many cases of these batteries rupturing and destroying the motherboard as a consequence. The shorthand for it is «Maxell Bomb».
