Quadra 950 - working or not, requesting some guidance
Alex
Dear members
I just purchased a Quadra 950 and it arrived safe and sound. The seller claimed that the power supply only clicked. My 4 year old daughter turned the key while just after I pressed a power button on the front facing panel and there was a chime, a loud healthy fan and a power light.
Now, I have no monitor to check and there is no HD.
Is this enough to confirm the machine works or should I ideally try something further. There also appears to be a 601 PDS card and a very large card that I suspect is a video card and gobs of RAM.
Any advice would be appreciated.
Many thanks!
—Alex
I would say a startup chime is fairly indicative of a working computer. Though a startup chime is a good sign, it doesnt necessarily mean your video card works. Next step is to go find a monitor, and plug it in!
Hi Themk
I would agree with the chime being a good sign. I have a bunch of Apple monitors but none that would plug in. The built-in video and the card both appear to host a DB-15, is that what these are called? Is there anyway to connect up to an RGB input, HDMI or ADC. I think those are all the monitor types I have otherwise I have to purchase a vintage Apple monitor.
Any thoughts, I have google and will investigate this but maybe you have some first hand info.
Cheers and thanks for the reply.
—Alex
