Quadra 950 Not Booting
If you have a scope or a meter capable of measuring high frequency, then check pin R7 and R9 of the 68040 to make sure the clock signals are going. If you don't have a scope/fast meter, measure those pins in voltage mode to make sure it is not almost 0V or almost 5V. Basically, a value in between suggest a changing signal.
I have a 2 chan PicoScope that goes up to 50 MHz, might not be capable enough. Thanks for the detailed instructions on the signals to check on. Could I also check the crystal's pins for a more direct measurement?
Measure the ohm of the speaker to make sure it is not open or shorted. I assume you've given the computer plenty of time to boot or show video, and haven't given up too quickly due to a lack of chime.
I mostly use compact Macs, so when I initially fired this machine up, I had it connected to an LCD monitor with an adapter with the dip switches. I wasn't getting any signal and I have used it before with (I think) a IIci. To be more conclusive, I would need to dig out an Apple monitor and try that assuming that works. I feel like this hardware has gotten to an age where almost everything has an issue, even if I have done some maintenance to it in the past 5-10 years. I did try another test speaker to see if there was an issue with the original one.
Any sound if you plug in headphones?
Might be worth seeing which other chips are getting hot other than the CPU.
I haven't given up, but for a couple reasons I thought I should look for another board. I have some events I need to prepare for the next couple weekends, so I had to tuck away the behemoth to keep it safe.
