Hello,
I have a Quadra 950, with a SCSI2SD version 6, set up for four SCSI HD devices at 2 GB each (ID 0, 1, 2 and 3).
After installing A/UX on SCSI ID 1 using the partition map and the guidance from the A/UX Server Penelope, I have some trouble installing and using System 7.5.3 (only with Open Transport), System 7.5.5 and System 7.6/7.6.1. However, System 7.1.1 (ID 2) and 8.1 (ID 3) are working just as anticipated, except they were installed before A/UX.
Symptoms:
7.5.3 (with Open Transport) -- ’Bus Error’ at boot (with or without Extensions off).
7.5.5 -- ’Bus Error’ at boot (with or without Extensions off).
7.6/7.6.1 -- Re-builds the desktop at every boot, and all the icons are gone (except for folders), even when booting from CD.
What is going on?
Symptoms:
What is going on?
