I have an Apple PowerPC 601 upgrade card that I want to run at 80MHz in my overclocked 40MHz Quadra 800. I replaced the 66MHz QFP 601 with an 80MHz rated part. However, the computer won't boot at 80MHz (crashes immediately upon loading from the hard disk). It at least chimes and shows video though.
When tested in a 33MHz machine, the card works without issue.
I'm thinking about replacing the Cache SRAMs (and maybe even the ROMs) with faster rated parts.
However, before I do so, does anyone know if there's some limitation of the PDS slot that prevents it from being stable at 40MHz no matter what? Or is it theoretically possible to get the card to work as long as I use faster parts?
