The MB has not been tested, I bought it dead. ATX PSU does work, was pulled from a working machine. I will double check the wiring.Are you sure that the ATX works correctly and have you wired correctly the PSU to the motherboard? Did the motherboard work?
I'm thinking that your 8100 motherboard could be bad, check for cutted traces or corrosion or even recap it, has your motherboard surface electrolytics or SMD tantalum capacitors?Just tested everything on the newly put together 8100 PSU cable, all voltages are good on every wire.
The original electrolytic caps are still on. There is no corrosion though, the areas around the caps look great, ill recap it tomorrow and give it a clean. Its a 8100/110.I'm thinking that your 8100 motherboard could be bad, check for cutted traces or corrosion or even recap it, has your motherboard surface electrolytics or SMD tantalum capacitors?
ROM DIMMs are in, the cooler is attached, ill check it for cracks soon and if its fine, ill replace the paste. Sadly I left the iron outside and it rained, ill dry it out properly and then do a recap if the CPU is fine.The 8100/110 should come with a Peltier equipped heat sink. The peltier is a solid state heat transfer device between the heat sink and the CPU which is powered by a plug on the logic board. Make sure you have the correct heat sink (equipped with peltier sandwich), make sure it is actually plugged into the logic board power connector (two pin, IIRC). Check under the heat sink/peltier and probably clean and replace the heat sink grease. At this age, it is probably powder. AFter you clean the CPU (isopropyl alcohol works well) check the body of the CPU for cracks. A large number of X100 machines are dead because of cracked CPUs.
Oh, do you have a ROM DIMM? The 8100 does not have ROM on-board. It needs a DIMM. That would be very simple.
Good job man, I'm happy for you!Recapped and applied new paste.
It chimes and boots to question mark, it will get a drive one day. Thanks for the help MrGas and Trag.
