After taking apart my 150, due to the display's bottom bezel detaching on the lower right, I found the hinges to be extremely stiff. I applied some grease but they remain incredibly stiff. After repairing the plastic and reassembling the machine the display bezel came apart again.
I can't find information on how to loosen the hinges grip which at the moment is so strong that it doesn't allow the display to be tilted without immediately breaking the bond that I applied. It should be noted that I was using JB-Weld Plastic Weld.
