PowerBook battery capacity wrong
mitchW
Any possible way to fix this issue with my PowerBook G4 battery?
It holds charge, but the capacity is reported wrong, therefore the gauge percentage is not correct.
I tried charging and discharging it few times with no improvement.
Thanks!
if the capacity is reported wrong, then the battery's cooked. Solution is to either replace the cells of the battery, which are just 18650s, or buy a new battery if soldering batteries scares you
That’s gonna be a BMS fault and won’t be fixed with new cells. My iBook G3 12” and G4 Titanium batteries have the same problem.
I am sure there is a way to reset the BMS, but probably needs some special software or even hardware.
Having such a large value, I think the BMS probably has encountered integer overflow so its capacity has "rolled over".
Value of 65483 (mAh) is very close to 65536 which is 2^16.
There was a battery firmware update for some PowerBook G4 batteries, which someone could have a peek inside and find a way to reprogram the BMS. I am sure there are lots of people with same problem - I own 5 G4 PowerBooks, and two of them have the same issue.
The battery holds its charge fine, lasts for about 2 hours... so I doubt it is a problem with cells.
