PowerBook 540c - Did a thing (OS 8.6)
Even more radical would be to get some sort of early Mac OS X running on it. One of the DPs, perhaps?
And 40 MB of RAM isn't necessarily a problem; Mac OS X 10.0 and 10.1 officially required 128 MB, but could install and run on 64. I once ran it on my Rev C Tray Loader iMac with 32 MB of RAM. Yes, thirty two megabytes. It was slow as h*** and thrashed the hard drive so hard I was worried it might die, but it actually worked!
Granted, this was on a Mac with a 266 MHz G3 running on a 66 MHz bus (compared to 100 MHz on a 16 MHz bus(!) ).
c
The RAM isn’t the main problem, it’s the architecture. Mac OS X needs Open Firmware, it’s fundamentally incompatible with anything Nubus/Slot Manager based.
Ah, I forgot about that.
Well, what other sort of exotic OS can a PPC-upgraded 540 run?
Does Rhapsody require OF?
c
The Mac OS X boot loader - BootX needs Open Firmware. So just create a new BootX that doesn't use Open Firmware.
Or, you can try creating a version of Apple's disk based Open Firmware that came with Copland D11E4 for the PDM Power Macs (6100, 7100, 8100). Maybe the boot loader that loads the disk base Open Firmware can be used as the basis for the new BootX?
In either case, you might need to make changes to the Mac OS X kernel (Open Firmware and BootX can apply kernel patches). And you'll need to create a platform expert kext and maybe some drivers, like XPostFacto has. You can use the disk to store NVRAM.
Anyway, anything is possible if you throw enough time and code at it.
Maybe some form of era-appropriate PPC Linux? Tagging @demik.
Yeah definitely since it's essentially just an earlier version of Mac OS X, based on OpenStep.
Not meaning to steal the thread... but I wanted to note this down somewhere. Since we've got G4 Minis running System 7.0 now, I wonder if we could modify the ROM or OF to allow "modern" PPC Macs to run NeXTStep and OpenStep as well....
For the 540c... it'd be really neat if we could force it to run System 6. But that would involve all sorts of hackery since it doesn't have OF available to provide hardware support outside the ROM and OS.
But a PPC upgraded 540c running System 6 would FLY!
How did you manage this? I have a PowerPC card now but I can't boot Mac OS 9.0.4. I get an error "This OS can't be used with this Macintosh" just after the splash screen appears.
Did you patch the System File?
Here are some notes I wrote up. Sure glad I did this, as I already forgot what I did. Can't take credit, borrowed from others to get up to 9.1.0. Still want to get to 9.2.2, just haven't had the time to play with this since December unfortunately.
Nice. I was searching the forums and Google for these instructions last night but came up short.
It's a very artificial imposition since there's absolutely nothing architecturally about the PowerBook 500 with PowerPC that's any different from a 2300 or 5300 Series, fundamentally speaking. The upgrade card even uses the same ROM as the 2300c.
So that means the 500 series is architecturally equivalent to a PowerBook 1400, because that's the same as a PB5300? Interesting.
Yes, once upgraded to PPC. The 1400 is basically a souped up 500! They all use the PBX memory controller/bus translator connected to an '030 peripheral bus.
Do you use a modified power supply for your Powerbook 540c or the original one? Have you tried creating and using a RAM disk using the Memory Control Panel in Mac OS 9? When in Mac OS 9.1, using the Startup Disk Control Panel do you see Netboot as an option? So many questions...
I guess performance is going to be even less than a PB5300/100 considering the 16MHz peripheral bus (vs the 5300's 25MHz).
Now that I have a 100MHz PPC card I did some benches in Norton System Info. I was indeed right about this, but what’s interesting is that this machine’s lower score is actually on a par with the Duo 2300c.
Of course we know that these PPC upgrades share a ROM with the 2300c and that’s going to be relevant.
I didn’t realise the 2300c was even slower (about 75%) than the 5300/100. You can see this in the included results for System Info. The dev note says the 2300 has a 22MHz peripheral bus, so somewhere inbetween the 500 Series and 5300 Series (but closer to the 5300). Yet the Duo is significantly slower, mostly in graphics performance. I wonder why this would be - I don’t think there is a performance difference between the CSC and ECSC.
