I’ve just rebuilt my PB1400c battery. I used tabbed ‘A’ cells that I got off eBay, and soldered them together. I get between 1:30 to 2 hours runtime in this configuration.
The correct batteries to get are the 4/3A ones if you want the most runtime possible, but you ideally need a spot welder as clearance is tight.
