Hello folks
I have two 2400c's. One of them has GLOD. The speaker clicks when I attach power and no screen. Up to now I have done the following, taken it apart, added a brand new battery and a brand new hard drive. I put it back together and no change, just GLOD and a single click from the speaker. No surprise there I guess. I checked all the fuses on the power board and all have continuity. I don't know where to go from here. I don't know enough about electronics troubleshooting to measure voltage which is where I think I have to go next, to understand where power is going or not going when it should. Can someone with more experience chime in and give me some starting points and a quick overview of how to check the power board for voltages? Maybe a video or a document? The adapter does work as it powers the other powerbook correctly.
Any advice is welcome. I will leave it here for now but if you need more info let me know, I can pull out the machine which is in pieces now in antistatic bags and provide photos if needed. Unfortunately schematics are no where to be found, at least I can't locate any. Thanks in advance!
