Powerbook 2400c with GLOD
Alex
Hello folks
I have two 2400c's. One of them has GLOD. The speaker clicks when I attach power and no screen. Up to now I have done the following, taken it apart, added a brand new battery and a brand new hard drive. I put it back together and no change, just GLOD and a single click from the speaker. No surprise there I guess. I checked all the fuses on the power board and all have continuity. I don't know where to go from here. I don't know enough about electronics troubleshooting to measure voltage which is where I think I have to go next, to understand where power is going or not going when it should. Can someone with more experience chime in and give me some starting points and a quick overview of how to check the power board for voltages? Maybe a video or a document? The adapter does work as it powers the other powerbook correctly.
Any advice is welcome. I will leave it here for now but if you need more info let me know, I can pull out the machine which is in pieces now in antistatic bags and provide photos if needed. Unfortunately schematics are no where to be found, at least I can't locate any. Thanks in advance!
A 2400c, probably more than any other classic Apple machine, needs a functional backup battery. By adding a "brand new battery," do you mean that you replaced the main battery or the backup battery?
Thanks for the reply. I have a working removal battery that I tried and the internal PRAM battery has been rebuilt and I can confirm that it works as expected. So to answer your question, both batteries are working.
Are you sure you've checked all the SMT fuses - IIRC there are 5-6 fuses on the 2400c motherboard, which is the main cause of GLOD on the machine.
Hi Byrd
I can't say with all honesty that I checked the motherboard for fuses. I didn't realize the MOBO had fuses. I know I checked the power board fuses several times and there is continuity. I will have to go back and check the MOBO in a few days. The last time I checked the machine was about 2-3 months ago when I had rebuilt the internal PRAM battery. I will check the fuses on the MOBO and then report back. I will provide a detailed report on all fuses checked so that it is here on the record. Thank you for letting me know!
In the meantime, just a quick question, are there schematics anywhere around? This machine has virtually no documentation to be found.
Hi Alex,
the lowendmac Duo mailing list (assume to find on internet archive) is where I found info about all the SMT motherboard fuses. I haven’t pulled my 2400c apart for years, but recall they are little white squares 5-6 all scattered throughout the board. Also, remember to use the power adapter to suit an iBook/PowerBook G3, not the “Duo” brick as it will kill the fuses. I learnt this the hard way!
JB
Thanks for reminding me of my own post. Oh my goodness, I forgot about that. I will review my own post and @Byrd thank you for the cautionary note. I have the bonafide Apple 2400C adapter so of course I will use that. Thank you both!
