PowerBook 180 no power (x2)
JRL
68000
So 2 of the PB 180s I picked up lately don't power up. One seems to make a small "blip" noise about every 5 seconds or so, the other has the screen turn on for about <1 sec. This is with both main batteries removed.
Are there any fuses I should be on the lookout for on this MB? Thanks!
-Jeff
First I'd check the PSU, and recap/recalibrate it under load.
There is a fuse near the DC jack on the motherboard that often dies, and can be replaced with some thick gauge wire; I did have a link but am not on my usual computer right now to find.
Are these PB 180 or 180c?
If PB 180c they need a good 3 ampere (24W) power supply and will only start for 1 sec with less than 3 ampere.
So did mine.
I found the female power connector soldered to the 180's mainboard to easily cause a slack joint. It can be damaged by bending the contacts, the solder pads in the mainboard can become loose, and also the contacts may corrode from the 3 A uptake of the PowerBook. My first PowerBook was pulled from my knees by the cable and fell just onto the plug. Both the cable and the jack broke. I fixed the power adapter with a new cable and a new plug (a flexible rubber stage quality microphone cable is appropriate for this purpose, and you can choose from many colours), and also soldered a new jack onto the mainboard. That solved any power problems in this machine for quite a long time, until all of the batteries died.
