Hi everyone,
I’m experiencing a strange issue with my PowerBook 165. The machine boots and works perfectly, the screen comes on with proper contrast and image… but the backlight shuts off after about 5 seconds. The image remains visible under strong light, so the LCD itself is fine — it’s clearly just the backlight that’s turning off.
After swapping parts with other machines, I’ve been able to narrow the issue down to the CPU daughterboard. If I install a known-good CPU board (e.g. from a PB160), the backlight stays on without any problem. But when using the original 165 CPU board, the backlight consistently shuts off a few seconds after startup.
Additional info:
Thanks in advance!
Additional info:
- The 165 CPU board is in excellent condition, no battery leakage or corrosion whatsoever.
- The issue is clearly hardware-related — it happens regardless of OS, and there’s no software control of brightness on this model.
- I’ve tried looking for schematics for the PowerBook 165 CPU board, but so far I haven’t found any available online.
- My suspicion is that the CPU board isn’t properly holding the backlight enable line high (maybe a weak transistor or open resistor), but without a schematic it’s hard to trace.
- a copy of the 165 schematics,
- or has encountered this issue before,
Thanks in advance!
