Posible conquest: LCIII!
You might be able to do the hack install on a OS 8 floppy disk set, but it'll take several times as long.
OK... i'm really not looking foreword to all of those disk swaps. would it be possible to install from my iMac via a network?
Network installs work for most classic macs. As long as you can boot with media that has appleshare client and network drivers, and your server has the files in the appriopriate layout.
Yeah, it will. You'll want to make sure you've got the correct drivers for your ethernet card on it however.
I can't tell from the other side of the world...can you access the iMac from the LCIII?
Or you could just buy/find a keyboard. ;) Head onto your local Freecycle and ask for an old ADB keyboard.
OK... i have OS 9.2.2 running on my imac. how can i get the iMac to appear in the chooser of the LC III, or connect to the iMac? I am running the 7.5 Network Access Disk.
Make sure you have the appropriate network extension installed!
Since your Ethernet card is an Apple one, you just need the Apple Ethernet LC extension which can be found here.
Um... the ethernet card needs no extra drivers! It saw my iMac in the chooser, but doesn't recognise that i enabled guest login, as i have no ADB keyboard i can't connect.
