HUH? I'm a happy camper. tragPExRocks!
Good to know. I never heard any more after the ones I mule'd over were delivered.Well, everyone who had a PEx without a ROM ... now has a ROM module.
Good to know. I never heard any more after the ones I mule'd over were delivered.![]()
That's fantastic! Glad you got it going.My PEx boots beautifully from trag's updated ROM! Thanks so much @trag you are THE MAN!
07:7d 3.9b7.1
"TriPEx.ROM"
- 0a3077fcb1218da339b038712a34d9db all 4MB "Boot PEX 0.1p..]"
- 6d4f4b536ef3e066fc73186305af0b32 first 3MB
- 2f15c6e6c336255802258212b2ae5bbc last 1MB
- Stored checksum: 4604518f 044640df.046cec63.02f77934.03db4e19 02ac9071.02e89b00.01e15d6b.025c19e9.0285d13d.034ce200.02016f25.027cc484:efbc0e0922ebe984
- All calculated checksums match the stored checksums.
- OpenFW is all zeros.
07:7d 3.9f1.1
"46001F1B - Power Mac 9700 Prototype (bad dump).ROM"
- 5e0f52e66117fb29dba9d7031c80f1ff first 3MB
- Stored checksums: 46001f1b 044641c5.046cec17.02f7762e.03db463b
- Calced checksums: 46021e8b x 044641c5.046cec17.02f7762e.03db45ab x
- Missing last 1 MB.
- Bad checksum main.
- Bad checksum byte lane 3.
"2.3 Power Express (9700 Prototype)/ROMs/test1digi.ROM"
- 58b8a8fadd5cc5bec6c3f8100feaceb4 all 4MB "................"
- 1f1790d0e888d2a46543577a97c352fe last 1MB
- Stored checksums: 46001f1b 044641c5.046cec17.02f7762e.03db463b 00913b74.009280da.008e989f.008fb2b4.009212a7.0093dbdd.0091ff8a.0091f053:8402e45b156e7a53
- Calced checksums: 46021e8b x 044641c5.046cec17.02f7762e.03db45ab x 02b555dc.02c83c8e.020e389a.0281b358.02b43b0e.02cb0ec4.0209d7c5.027b36ba:294b04602916fbba x
- Same first 3 MB as above.
- Bad checksums in the last 1MB. Those checksum appear to only be calculated using the last 1MB. See 1MB test1digi below.
"2.0a9 Power Express (9700 Prototype)/ROMs/test2orig.ROM"
- 296558a210dfb961ff2b1b7495d2de84 all 4MB "................"
- 9728d9a3c6777ffbb40f35d21e0c4c93 last 1MB
- Stored checksums: 46001f1b 044641c5.046cec17.02f7762e.03db463b 00987ae7.00806b6d.0097b408.006e9dbe.0099cfd4.00819f6c.009af754.006f84a6:ea9040100ed2d8a6
- Calced checksums: 46021e8b x 044641c5.046cec17.02f7762e.03db45ab x 02bc954f.02b62721.02175403.02609e62.02bbf83b.02b8d253.0212cf8f.0258cb0d:8fd86015227b5a0d x
- Bad checksums in the last 1MB. Those checksum appear to only be calculated using the last 1MB. See 1MB test2orig below.
"Digibarn/SIMM/Rom-grabber/ROM-image 01.rom"
- a42b0536b6a741d8208a5202d3785e7d all 4MB "Boot PEX 0.1p..]"
- ae53d1e2870f26022c0942647a67d0a5 last 1MB
- Stored checksums: 46001f1b 044641c5.046cec17.02f7762e.03db463b 02ac8c53.02e8c2e8.01e122ba.025bd32c.0285de89.034cc158.0201aefd.027d0c1a:f96916594e84091a
- Calced checksums: 46021e8b x 044641c5.046cec17.02f7762e.03db45ab x 02ac8c53.02e8c2e6.01e122ba.025bd32c.0285de89.034cc158.0201aefd.027d0b8a:f96716594e84088a x
- bad checksums in the last 1MB only for byte lane 1 and byte lane 7.
1MB Parts
1f1790d0e888d2a46543577a97c352fe "www.jkalittle.co.uk/OF_2_3_dump3 duplicate of test1orig_plcc and last 1MB of test1digi/full.rom"
- Stored checksums: 00913b74.009280da.008e989f.008fb2b4.009212a7.0093dbdd.0091ff8a.0091f053:8402e45b156e7a53
- Calced checksums: 00913b74.009280da.008e989f.008fb2b4.0092135e.0093dbdd.0091ff8a.0091f053:8402e45bcc6e7a53 x
- This file contains the 9 checksums in the config info. They seem to be valid without the first 3 MB except for byte lane 4.
- The error in byte lane 4 also appears in the 5th byte of the 64 bit checksum.
9728d9a3c6777ffbb40f35d21e0c4c93 "www.jkalittle.co.uk/OF 2.0a9 duplicate of test2orig_plcc and last 1MB of test2orig/full.rom"
- Stored checksums: 00987ae7.00806b6d.0097b408.006e9dbe.0099cfd4.00819f6c.009af754.006f84a6:ea9040100ed2d8a6
- Calced checksums: 00987ae7.00806b6d.0097b408.006e9dbe.0099d08b.00819f6c.009af754.006f84a6:ea904010c5d2d8a6 x
a3c65d883ecd63c56771d316e9c875a5 "www.jkalittle.co.uk/OF_2_3 bad dump - bit 7 stuck high/full.rom"
- Uncorrectable problem - bit 7 stuck high.
4adac49abe6adc8e3cdf25f35aaf2326 "www.jkalittle.co.uk/OF2_3_dump2 bad dump - blocks repeated every 4K/full.rom"
- Uncorrectable problem - blocks repeated every 4K.
