Simple question, but I can't find a simple yes or no out there.
The floppy on my 631 is acting up, probably just needs a cleaning. If I need to ultimately replace it, do I have to find another manual inject, or can I use an auto-inject superdrive in this machine?
on a PCI based power mac, if you use an auto inject drive, it will repeatedly try to eject a disk. Manual inject drives are relatively cheap on ebay. i just bought a NOS one for only 40
