If you put all the voltage regulators in one box you could use a different size barrel jack for each voltage. Then you wouldn't have to worry about voltage switching and it would be impossible to accidentally connect a laptop to the wrong voltage.I had thought about that actually earlier today. Would be neat if I could integrate an automatic voltage switch or something inside of each tip instead of relying on a dial that I'd have to set each time, would kill two birds with one strong. So yeah that may be the way to go. I'd just have to find a high quality self-contained step down converter for each voltage, seems doable.
What's really annoying about the 3-pin Dells is that halfway through their use of them they switched the key of the tip and the voltage. The XPi and LM series used a 16v with the different keying IIRC, and starting with the CP/C series and associated Inspirons is when they switched to 19/20V and the more common keying. I've seen plenty of cheap untested Latitude XPis and LMs on eBay that I'd loved to have bought to mess with but I've yet to find one of the earlier chargers. You can pretty easily modify a later C-series charger to fit in the earlier ones, but the voltage is trickier.
I found out female Dupont wires like they use for gpio on raspberry pis fit tightly over the pins on those 3 pin dells and 4 pin IBM's. You can attach the other ends to a barrel jack and use a 16v ibm or whatever adapter to power it. I had to do that to test a Thinkpad 760cd. It's not ideal but it works for testing. For permanent use you could cut the cord off the more common 20v 3 pin adapter, solder it to a barrel jack and use a 16v brick to power it.
