PB 1400 40MHz Overclock
It’s safe to try, but do you know the resistor values for 133MHz operation?
I am planning to overclock crystal :D
You might be the first person to attempt an overclock on the humble 117MHz module, ha.
I'm sure I won't be the last! PowerBook 1400/117MHz modules are fairly plentiful, because so many people have upgraded them to 133MHz, 166MHz or G3 CPUs. I figure that if th chip itself can handle the higher clock speed (i.e. rated at 117MHz, because they didn't test for 133MHz), then it should still run cooler than a 133MHz module with an L2 cache.
OK, so it'd probably only be a 7% to 10% improvement, but hey, the equivalent of 125MHz or 128MHz would still be a good thing!
It might boost the overall performance of the 1400 to:
PowerBook 1400/11712414392118
(7% boost)13315398126
(10% boost)136157101129
Then the CPU would beat a Performa 6320/120; the FPU would beat a PowerMac 8100/80 my SD based drive would finally get above performance of a PowerMac 6100.
Happy days ;-) !
I didn’t understand your table. What are the different columns representing?
Even at 133MHz It definitely won’t run as fast as a 6320, I’m afraid, as that machine has 256k L2 cache.
Ignoring a probable better RAM architecture, cache and bus, in terms of raw CPU, a 117MHz should slightly outperform an 80MHz 8100 anyway. The cache and bus benefits will wipe away that advantage, but in pure CPU MIPS, a 603 needs to be about 30% faster to match the performance of a 601.
A 32k cache was a 14% uplift in a IIci, but I forget what it is for a 256k on an 8100 or similar.
