Hi guys, I've bugged some of you on IRC pending my account but figured I'd pick non-lurker's brains. And yes, I have Larry Pina's book on the way but I have no idea when I'll get it (Amazon used seller).
Anyways, the analog board on a Classic II I picked up is putting out particularly low voltages - just under 10 volts on the 12 volt supply and 3.9-4.1 volts on the 5 volt side. This is testing directly off of the hard drive power connector with the drive itself unplugged and the logic board unplugged. I tried fiddling with the PP1 variable resistor and it didn't make any difference (and no it was not already cranked all the way down, the machine has not been opened before).
Does this still suggest only a recap should be necessary, or is some other component (or components) possibly out of spec as well?
