Need help pointing to strange video problem on SE/30
I am working on a buddies SE/30.
This one here seems to work, it boots up… sound works. etc.
Except this video issue. its like a whole block of video lines are out. if i had to guess i would say lines 0123(work) and 4567 are dead.
I did some continuity checks, from UE8 and UC6 - UC7 and only one line was out, I ran a wire and fixed that.
before i spend any more time on this can anyone look at this and help me shotgun the issue?
there was quite a bit of cap leakage around UE8.
there was quite a bit of cap leakage in general.
here is a picture of what i get on the Tube,.
thanks
Issue cant really be "shotgun guessed" by anyone else but yourself, Only reason why I say this is because every failure is going to be unique in which traces and chips are gonna be bad in your board.
But I digress...
But i think your right, your missing the upper nibble of the databyte. And an easy way for that to be the case, is the upper/lower select signal.
Yeah I'd agree with techknight, your upper 4 bits of the Vid signal are out. So your issue is centred around UC6 as Vid(4) to Vid(7) are stuck on low (screen black). It's possible that those four lines happen to be bad but somehow I reckon that it may be on the input side of the chip.
I would get the schematics and check every connection on UC6 including power / ground. I'd say you'll find something wrong there. If not, work your way back to the mux's UA8 to UD8.
Good luck :) !
Thanks. I'm spent on time right now.. i have other boards to do. 3 more se/30s jus came in. and a nice IIcx is waiting for service.
i do agree that the issue is something with UC6 or something that should be feeding UC6.
i appreciate your input as always. really!
hey guys the only thing i can think of is UC6 is bad... one other thing i would like to say it seems UG7 gets hot to the touch after not too long at all.. all the other chips around it do not even get warm.
i am wondering why... i swapped that chip with one from a donor board, it still gets hot like the original one. and still has video issue. I used my meter, and man its like every dam trace is proper, i can't find any issues...
i would swap out UC6, but its soldered, everything to it appears to be the same as UC7 i even checked voltages with the board on.
I cant swing any more time on this for now, my buddy is gonna have to spend some more hours with it.. Maybe he can clear the video up.
other wise, all works...
If UG7 gets hot, there's definitely a problem there somewhere. I guess you took out UG7 and checked all the pins for any shorts already. I'd even check if any of the pins are somehow connected to each other when they shouldn't be and that none of the pins are shorted to power or ground.
I'd also be careful not to damage those PAL IC's like UG7...not like you can buy more...hot = bad :)
Troubleshooting...if only there were more hours in the day...
PS: had a quick look: UC7 pin 1 receives it's clock signal from UG7 pin 15. Also UA8 pin 6 receives multiplexer input from UG7 pin 12. So there is some interaction between the possible problem sources. If one of the mux inputs is bad it would mean the vrams UC6 / UC7 wouldn't be addressed correctly. Would that result in the pins stripe? I have no idea right now...maybe worth checking those two connections though...
i checked that and it doesn't get 000 continuity it gets 022
so i guess that means there is some resistance.
i checked that and it gets 000 continuity, so its good.
thanks man.
The 22 is actually correct. There is a 22 Ohm resistor in between so that's OK as well.
I guess you just have to start checking out UG7 and anything it's connected to...bummer!
Yeah with this stuff it's time, time, time,
and unfortunately I'v way over extended my time budget on this thing.
my time at home when i am not at work is really getting quite valuable these days.
between the re-caps and the kids… an occasional bite to eat, and some sleep in there some where… there aint much left :(
I'v found the problem
in this rare occurrence the issues was the UE8 I/C its self.
i changed it with a parts se/30 board and the video not works fine.
i also fixed 2 other se/30 boards with the gangster stripe issue tonight.
so it looks like i'm on a roll.
Yeah with this stuff it's time, time, time, and unfortunately I'v way over extended my time budget on this thing.
I forgot to add my normal day job in there :-)
Vias can be notoriously problematic on some boards. They are created by a relatively thin layer of plating applied to the hole drilled through the board. Contact area with the traces on each side is very small and over time thermal expansion, flexing of the board, and/or corrosion can damage the via and you get an open connection. There can be dozens and dozens of vias and all it takes is one bad one to cause a problem.
