I've got a PowerBook 1400c/166 that I'd like to test before buying a power brick for it. Since I have an iBook A1036 charger that has the same voltage and current ratings, I was wondering if I can put a 1400c compatible connector on the iBook charger to test the 1400c. However, some of the pinouts I've seen for the iBook charger show a resistor between shield and GND (I've attached an example). Will excluding this resistor harm the 1400c or the charger, and are there any possible issues with using this charger at all with this computer?
Thanks!
Thanks!
