Hi all, new to the forum came here looking for some help...
I have a Macintosh LC III that was not booting up. I replaced all the caps on the logic board, and voila, sweet chimes and bootup.
When it started, I got the flashing questiong mark disk, meaning no OS found on the HDD. I tried with a floppy disk that’s bootable (system tools), nothing... Since I also have a Floppy Emu I thought of using that, however no matter what image I mount, it just stays there at idle and never reads...
Since I have another LC (a I) that does work (after recappping the PSU), I double checked in that one that both the floppy and the Floppy Emu worked, and they do.
I swapped the HDD, and the LC III did start to boot (but stopped saying the installed OS was not compatible with it, blah blah).
So I thought, ok, HDD has no system let’s install one.
Inserted it into the LC I, and when I try to install it, the disc is not detected
I also tried disk sc, etc , nothing, the disk is jut not found so I guess it’s just dead..?
Anyway, back to the original issue, not really sure how to troubleshoot/fix if possible the issue? Can it be the floppy controller? (Swim chip?? Which is it?) something else? Because the floppy *drive* itself works, as does the one from the LC I, and as does the floppy emu, but when plugged into the floppy connector of the LC III nothing does.
Help
Help
