Here's a quick thing I've been working on: a testbench style case for IIcx/IIci and related designs. Quadra650 board could fit, but some of the mounts will need to be removed as they're in the wrong place. Don't know that i have it in me to finish it out into an actual complete case but figured I'd post in case it's useful to someone. 3MF and STEP files in attached zip.
Designed to be 3D printed in 4 pieces, and then glued together. Requires around 350-400 grams of plastic (depending on infill setting). All sections should be printed with support enabled in order to support the teeth of the PCB mounts. Mind that you get your extrusion dialed in just right - I made the dovetails to fit tightly together so if they're slightly out of whack it'll be impossible to get together.
Some minor issues with it, I had to file the rear right mount a little to fit my IIcx board, and it could do with being a little longer if more than one extremely long card is needed (radius rocket...). Overly long cards will overhang the front in the first slot, or hit the front in the other two slots.
