Bit of an odd one this. I was sent a 512k which was a little bit... erratic. Sometimes it will bong and flash the floppy icon, other times it will just get stuck on a corrupted screen. Thinking it was a RAM issue I took the logic board and found out that for some reason someone had removed C5 and C20 at some point (?!). I know there may be ram issues or potentially issues with the roms, but I just need to find the values for those two capacitors to rule that out as an issue!
Hope you can help
Hope you can help
