Mac Plus Floppy Eject Motor Won't Stop
CC_333
68040
Hi,
Why is this? I thought I saw somewhere that I could cut a wire on the ribbon cable to fix this, assuming it's not the drive itself that's acting up (it seems to otherwise work fine, booting up the machine and all, so I kind of doubt the drive's at fault).
Any ideas out there?
c
There is a mechanically actuated switch mechanism, in the motorized disk eject unit.
- You could swap that whole unit out for a working one
- You could just unplug the eject unit
- You could take apart your eject unit and see why its not auto shutting down the eject motor.
Hi,
I checked it, and it seems to be OK.
I suspect a replacement eject motor would behave the same way.
I will try borrowing a floppy cable from another machine tomorrow to see what happens.
I definitely thought I saw somewhere that cutting a certain wire of the cable disables some sort of sensor or cut's off some sort of control signal from the floppy drive which can cause this problem in certain machines.
c
I had SE FDHD with a bad filter chip on it, the issue with that was, It would randomly tell me the disk i have inserted is unreadable, and would I like to eject it? Even when there was no disk in the drive.
Hi,
Well, I tried different cables, different drives, even a different logic board. All had the same problem.
Why??
Any thoughts or ideas?
c
Hi,
I found what I thought I saw before:
Floppy drive won't stop ejecting
It says to delete pins 9 and 20 to restore proper operation.
I did pin 9 (I think), so I just need now to understand where pin 20 is.
The wire which corresponds to pin 9 is 3 wires to the left of the right edge of the cable if the colored stripe is on the left. What wire corresponds to pin 20?
c
you can try this lift the green board at the front of the motor. just lift it a little.
there is a reed switch under it clean out the dust, than push the board back down
On all three drives?
I checked on the first one, and aside from seeming a little fatigued, it was OK. I bent it back tinto shape and reassembled it to find the same exact problem.
I think it has to do with the cable problem as described in the thread linked above. I just would like to know how to modify my cable such that those two pins (9 and 20) are disconnected. Maybe then it'll work.
I might add that this cable isn't original to this computer.
c
Problem Solved!
I found a spare, yellow-stripped cable, and, for reasons unknown to me, it works perfectly! I now have yet another fully functioning Plus.
I still have the other cable, and, even though I cut a hole in it, it seems to work just fine, so I'll keep it for something else (other than a Plus).
This should be documented more thoroughly and completely.
Thanks!
c
