Mac Plus and External SCSI
If you plan on using a ZIP drive you will need the Iomega 4.2 driver in order for it to boot the Plus. That also brings up some questions about formatting with third party utilities to be startup disks. Having never really used an external HD on a Plus, I merely pose the question. I do know that formatting third party drives was always a headache on the early Macs.
Sorry to resurrect an old thread, but I wanted to point out that you do not need the Iomega 4.2 driver to boot the Plus from a zip drive. I have a Plus setup booting happily off of a Zip100 drive using the LaCie Silverlining 5.x driver.
-10d
Also, you can use the patched Apple SC HD Setup to format ZIP disks, and the OS will treat it like a regular hard disk. The only disadvantage of this is that ejecting is now a two step process (you must press the physical eject button on the drive after (not before) you've unmounted the disk. Also, there is nothing preventing you from removing the disk before unmounting (unlike the Iomega drivers), so there's a risk of filesystem corruption if you don't follow the proper "order of operations").
Of course, if you're mindful of this one "caveat", it's a very excellent and compatible hard disk solution (this way, it will work with any Macintosh/System Software combination that supports SCSI, and it's easily swappable between other systems, new and old). It's also quite bootable, supporting everything from System 6 through Mac OS 7.6 (I've never tried Mac OS 8.x or 9.x.x, but, given the proper conditions, I don't see why not).
The only possible downfall is that ZIP disks and drives might be a bit less reliable (depending on age and quality of materials) than an equivalent hard disk. The upside of this, however, is that both the disks and the SCSI-based drives (especially the externals) are still relatively plentiful, making replacements fairly easy and affordable to acquire.
I hope this is helpful.
c
p.s. I'd like to note that I tried to replicate this process using JAZ disks (which are similar, but use a different type of disk to increase capacities to 1 to 2 GB), but the drivers are such that I can't replace them with the standard Apple ones, unfortunately (perhaps there's a way around this, but I haven't discovered it yet. In the meantime, the regular JAZ drivers seem to work fine on most models I've tried them on).
