M5126 help! I am stupid
Good morning, time has passed since this thread but I find myself with the problem that I can't find a spare part for this F1 its fuse resistance?, would you be so kind as to tell me where I can buy it or the values to look for it? All the best
You're looking for an "axial fuse". @Bolle says 7A. If you search for a 7A axial fuse you'll find lots on, for example, mouser, then narrow it down to one about the right length. As long as it is more than the battery voltage, the voltage doesn't really matter, and it doesn't matter what it looks like.
