Hi, :beige:
I'm recapping my Plus analog board, but the fuse holder broke of (Part F1 on the analog board (international version)). I noticed it barely had a connection with the fuse, and just touching it made the metal break off.
Do anyone know the part number for the fuse holder?
Same with the metal pin inside the anode cap, when I took off the anode cap the pins broke off. I fixed it with just putting some wires in between to make a connection, but as I need to order a fuse holder I rather have the original part if it exists. It's the plug that makes the anode attach to the CRT. It has a screw inside the cap, so it's easy to replace once I find the part.
Do anyone know the part number for the metal plug inside the anode cap?
I tried to search for these parts, but I can't find them anywhere..
