Thanks for doing this imaging? Which one is missing?bad news is out of the 5 install floppies, only 4 were available in the original set…
Good to know, thanks.It could be that there is no Disk 5 for 2.0
As for emulation - my copy of LisaEm can't install LOS 2.0 in any language currently, for some reason. I'm working on getting it working, but at least I can see the install prompt in French for your first disk, and the tool disks mount correctly, too.
I took a look at these images today, and the disk Macintosh Repository (and others) have labeled as Disk 5 is actually LisaGuide 2.0. I think this means that we do, in fact, have all of the OS disk images for 2.0F!Images found online (Macintosh Repository) have 5 disks ? (oddity ?)
we have all of the OS disk images for 2.0F!
the French install is still giving me trouble with that same "cannot write to disk" error you saw at random points in the install process. Back to the drawing board
to install LOS 2.0 in English and German
Through LisaEm, you can create new ProFile images, install whatever you want on them, and save them as 5MB disk images. You can then take whatever ProFile images you like and attach them to LisaEm (and specify which you'd like to boot from). It's possible to load several at once by emulating a dual-Parallel card (or several)you can create as much Profile drives as required and boot from them using preferences ?
If you still had access to the Lisa and drive you mentioned in your first post, this would be a way to get a version of LOS 3.1F archived without having the install disks. Is this a possibility you could look into?
