LC630 DOS Compatible supports 64MB SIMMs - 84MB total!
Were they FPM or EDO? I thought the DOS card took 64s, but only FPM?? Or something like that. Suddenly cursing my lack of 64MB SIMMs for testing.
I'll have to post back when I have that machine open again, but EDO vs FPM would make sense. For some reason I photographed every internal component other than the RAM I was installing I guess :/
So, has anyone pushed their 630 DOS system to the 196MB maximum that was discussed here? MicroMac claimed it was possible with their bigSIMMS products https://www.micromac.com/products/bigsimms.html.
Confirmation of both points: yes, I had been using 64MB EDO SIMMs which explains why the DOS card didn't like them. Thanks for mentioning it!
And these SIMMs together achieve the full 196MB:
So, droppin' a bit of money on some new RAM for my Performa 640CD DOS...
128MB double bank 72-pin 60ns FPM
64MB single bank 72-pin 60ns FPM
These are max for the 2 slot 630s. I'll find out in a week or so if it's the same for the 640!
Does anyone know the /actual/ max for the DOS card? I had a 32MB in it, but I've moved that to the Mac until I get the above sticks. We know 64MB FPM won't work in it (Thank you jeremywork!) But would 64MB of EDO work? 128MB?s
64MB FPM should work in the DOS card, but EDO won’t (which is what I had tried.)
640s should be the same as two-slot 630s; the photo I posted was of my 640CD.
My bad. I got FPM/EDO reveresed regarding the DOS card.
Thank you for clarifying! When I get the 128MB module, I'll plop that in the DOS card and see if it works.
Also, in theory, if a stick of 256MB, single sided, 60ns, FPM RAM were to be made/found - it could potentially be used in these Macs? That's probably impossible without some circuitry magic, but in theory possible?
So, I bought "64MB FPM MEMORY NON-PARITY 60NS SIMM 72-PIN 5V 16X32 SOJ OR TSOP" from ebay - works' well for the Mac. I tested it in the DOS card, and Windows only seen 16MBs - 1/4 of the total. I barely knew much about RAM back when these things were current, but could FPM w/ Parity potentially have a different result?
I also bought "128MB 72 Pin FPM Memory SIMM 5V 60ns" on ebay as well, which also works in the Mac (a full 196MBs! YAY!)
This also does /not/ work in the DOS card.
A couple months ago, I bought "32MB 72-Pin 60ns FPM SIMM Non-Parity Memory RAM 16-Chip Apple Macintosh PC UNIX" to use in the Mac for testing, as it came with 2x 16MB sticks total - 1 in the Mac, 1 in the DOS card. This 32MB FPM /does/ work in the DOS card
2x 16MB SIMMs 8+4 chips, all "IH5117400-6" with a double-height P to the left, made March '97 with "USA" on the chips, but:
the module reads "810-44-3568 / Made in Taiwan"
In this case Parity wouldn't help. Parity is for error checking in computers that support it.
Sadly same size SIMMs were available in different configurations in that era - there were various refresh rates as well as sometimes, sort of, the same size might be made up of different numbers of rows and columns, or different numbers of banks of RAM. Its an absolute nightmare.
Has anyone ever got a 64MB SIMM working in a DOS card? Sadly (and surprisingly) I don't own a single 64MB 72pin SIMM.
My tests:
⬇️Module | Location ➡️Other markingsChip markingsMac DRMac SRDOS card
16MB*810-44-356B
(PCB)
P IH5117400-6 | 9703 USA✅✅✅
32MB DR FPM NP11153-0001 032M
TECHWORKS 9811414
(small sticker)
9810 S USA
MT 4C4MB1
DJ -6
64MB SR FPM NP (16x32)(HJ) M1 94V-0
(PCB)
SEC KOREA 822
KM44V16100AK-6
TCD030BB
128MB DR FPM NP2129 (HJ) M2 94V-0
(PCB)
CE 1543159 RoHS
23209 July, 2023
128MB / 72 PIN
(sticker)
NEC JAPAN
D42S65405G5
-A60-7JD
9918E9009
Listing out what I know works and does not so others might have a good idea of what to get :)
NOTE: the 16MB modules have chips on both sides, 8 on one side, and 4 spaced out weirdly on the other side. The chips are mounted with the chip legs in rows perpendicular to the SIMM slot.
The 32MB SIMM also have the RAM chips in a vertical orientation with the chip legs perpendicular to the SIMM slot.
My 64 and 128MB modules both have 2 rows of chips, with their legs parallel to the SIMM slot - the 64MB module having 8 chips on one side, and the 128 having 16 chips total. I know physical orientation *may not* have any affect on operation, but maybe? *shrug*
Everything I've read suggests 32MB is the absolute most the DOS card can handle. I don't know if that's actually true or not. Everything I read about my P640CD is 52MB max limit (4+32+16) and yet I've got it up to 196MBs!
I have found 64MB modules that are single sided and with the chips oriented so the chip legs are perpendicular to the SIMM slot. The one I have/tried is 16x32, the one I'm looking at is 16x36 (which apparently means it's parity ram... makes sense) It's $20, so worth a shot. I'm sure I have an old PC that'll take it if it don't work in the DOS card.
btw, when I put the 64MB Single sided, non-parity FPM in the DOS card's slot, Windows 95 seen it as 16MBs only.
Parity has nothing to do with whether or not a SIMM works in the DOS card - don't buy it. Spend the money on a pizza and a few beers instead.
Like I said, not exactly a waste - I've got other retro projects to work on, and will have use for more RAM.
Anyways, it came in today. I got it installed... annnnd 16MBs seen by the DOS card. I'm not sure if it's seeing the chips at 512K each, or what.
I was hoping the different arrangement and chip capacity would change the outcome, but alas, I've now got a spare 64MB stick to plop into another machine lol.
Seems odd that it would downrate 64MBs to 16MBs instead of capping out at 32MBs. I wasn't a PC person back when EDO and FPM were "current" and wasn't very technically inclined (comparatively, to others my age, I was considerably more technical) But yeah, is that common behavior? In SDRAM days, I had a PC that had 512MBs (2x 128, 1x 256) but would only ever show 384. Just truncated the 256... but thinking about it now, was probably the eMachines or Gateway (I forget the brand) BIOS artificually limiting the RAM.
EDIT:
So, out of S&Gs, I installed this 64MB stick into the Mac, second slot (single rank slot)... and the Mac is using all 64MBs. The single sided 64MB I bought for the Mac, is in the dual rank slot... bringing a total of 132MBs. I assumed since the chips were on each side it'd be dual rank, specifically what the Mac cannot use in second slot. Different physical layout, same logical/electrical layout as the other module though. Oh well.
I wish I had discovered this thread before buying and receiving a 32MB EDO SIMM to use in the DOS card… Because it doesn’t work, the PC won’t even boot! I then tested a 16MB FPM SIMM that worked just fine, all 16MB checked during the PC boot phase. So I think it can be confirmed that the DOS card only accepts FPM SIMMs.
It’s rather unfortunate that all the information from back in the day about RAM upgrades for this Mac and the DOS card makes no mention of EDO (or FPM for that matter). Maybe at the time EDO SIMMs didn’t exist yet?
The maximum amount of RAM for the DOS card seems to be 32MB, according to the developer note (page 19):
The main compatibility card has a slot for one 32-bit-wide SIMM that supports up to two banks of DRAM (for double-sided modules). No system DRAM is soldered on the card. A single-sided SIMM can hold 1 MB, 4 MB, or 16 MB using 1, 4, or 16 Mbit DRAM devices, respectively. Double-sided SIMM modules can hold double those amounts of memory.
The DOS compatibility subsystem does not require a DRAM SIMM with parity.
I quit messing with this shortly after page 1 of this thread so I'm still at 148MB on the Mac side and 32MB on the PC side. Wish there was a chance for more on the PC side but it appears that we've exhausted most or all of the ways to get there without finding one that works. I'm pretty happy with what I ended up with, even 32MB RAM was ludicrous back in the Windows 3.1 days...
FWIW I picked up this particular LC630 at a school auction in I think '98 or '99 and it had 8MB RAM on the Mac side and 4MB on the PC side. I remember picking through the pile of computers at that auction and it had by FAR more memory than anything else there... almost everything else was Apple IIc, IIe, 286/386 era stuff. I remember thinking that it was weird that it made it to auction so soon but I still only paid like $20 for it.
I ended up working at that school in '04 and '05 and that was when they really started dumping all the old Macs. Lots of pizza box LC's and AIO 5xxx Power Macs! I miss those days, it seemed like every room had something different and there were lots of one off computers like this one - I can say with 99.9% certainty that there was only one DOS compatible LC630 in the whole district.
I knew a guy who was responsible for “disposing” of all the old 80s and 90s-era Apples and Macs from the University of Washington. This was about 25 years ago. He came away with hundreds. Filled up his house and garage. I don’t think he paid anything for any of them. Knowing at the time I was into these computers, he said come by and take whatever you want. For a $20 I filled the bed of a Dodge RAM D250 and all the unoccupied space of a Nissan Altima with everything from IIgses to SE/30s to Quadras. Boxes of ADB keyboards and mice. I had close to 40 of just various compact Macs. Those were the days, indeed.
Back to the topic at hand, can anyone tell me why the “larger SIMM” thing doesn’t work in a PowerMac 6300, which is supposedly based on the 630? I’ve never been able to get it to see/use more than 64MB.
