So, with a lot of fuss and hoo-ha, I've got an LC 475 up and running 7.6.1. One of the problems I've run into a lot recently, and not just with this particular machine, is that the data transfer from the floppy drive (or Floppy Emu using different cable) to the HDD tends to be sketchy. The hard drive doesn't have any bad sectors and runs perfectly fine on its own and networked file sharing transfers are fine as well using AppleTalk. However, when it comes to getting something off a floppy, including the system files, it's a nightmare.
I'm usually met with a message at different points of the install that an error occurred and it rolls back the installation. It's not one particular floppy disk, because this occurs completed at random and at a different point nearly every time. I similarly get error -72s when attempting to make disk images using Disk Copy 6.3.3 (and 4.2 for that matter). The only solution to the system installation was to do a bare minimum install of 7.1 (3 floppies) and keep trying until the system finally makes it onto the HDD. Then, I drag the System 7.6 disks over to the HDD and later install from folders. This is a long process given that the transfer fails perhaps 1/3 of the time for each disk. Again, it happens both with physical disks and the floppy drive as well as the Floppy Emu. And again, I've experienced the same sorts of problems exhibited on my Performa 630 as well.
Any thoughts on what the culprit might be? Many thanks!
