Large Box 'o' Laptops
Long time coming this box was originally promised to me a year ago. I got an email last week saying that it was finally out of storage and ehre is what I picked up today:
Powerbook G3 Lombard - 400mhz/?MB/0GB/DVD - Comes with a spare logic board. 1 is good, 1 is not...not sure which is which.
Powerbook 3400c 180mhz/144MB/1.3GB/CD
Powerbook 3400c ?mhz/144MB/?GB/CD - Not Booting properly. Has tape on it with 'Suspect PowerBoard'
Powerbook 3400c ?mhz - Taken Completly Apart. Motherboard is apparently good, has a 16MB RAM card.
Powerbook G3 Kanga - Bad Powerboard or something. Turns on but Whines quite badly. Apparently it destroys Hard Drives.
Powerbook 1400c - No idea of the CPU or RAM and apparently it gets a line on the LCD at boot but it goes away. No CD, battery or floppy.
Powerbook 170 - No idea what it has inside. No Power adapter means no testing :(
Powerbook 190cs - Not tested yet. Looks complete.
Powerbook 520 - Case is very beat up 20MB RAm/500MB HD. Screen is almost broken off. 1 Hinge broken
Powerbook 520c 12MB/320MB - Works and case is decent.
Powerbook 540c 20MB/250MB - Works and LCD is a little discoloured but okay otherwise.
Stylewriter - No Power adapter
Box of 3400 Batteries and floppies.
Now I just have to go through it all!
This box has given me a lot of projects.
Project 1:
So I found out the 1400c was a 117mhz by the CPU. It did not boot but it was missing all the RAM. I plan to move the LCD to a known working logic board and bottom case.
Project 2:
Replace the logic board in the bad 3400c with the possibly working one. Messy I think.
Project 3:
Replace the logic board in the Lombard.
Project 4:
Gut the 520. It is in very poor shape case wise but it still booted. Good for parts.
Project 5:
See to fixing that Kanga. Doubt there is much I can do for it but one can hope.
I forgot to mention there was a Bookendz by NewerTec in the box for a lombard.
Wow Strimkind, you made out like the proverbial bandit! Where did this haul come from?
Nice. The 400MHz logic board includes the hardware DVD decoder. And the Bookendz dock is a sweet bonus.
Powerbook 520 / 520c / 540c
You know the CPU modules are interchangeable, right? And you can upgrade the 520s to 33MHz for a buck apiece. Heck, get spares and see if you can upclock them :D
It Came from someone who used to restore them and send them to the Philippines. These were what was left over and would have gone to the recyclers if I did not take them. He has other computers that he is going to let me know about down the road.
Indeed it is. I think I have to do a motherboard swap before I can get this beast working though. Not looking forward to that.
They are. I should buy one for the 520c as it is in Okay shape. The 520 is pretty much a writeoff. The hinge for the screen on one side is completely broken off the case and there is missing front plastic on the 520. I consider it parts. Not bad considering there is a 500MB SCSI drive in there.
Either way, my wife rolled her eyes and sighed when I told her about this box.
Also, anyone know where I can find a really cheap power adapter for a 170?
The fact that its missing all its RAM is irrelevant - all PB1400s have 8MB soldered onboard, in addition to an extra 4 or 8MB in the Apple RAM slot.
Anyway, great score :)
