Having a weird issue with an external disk I have had for a long time. I just reformatted and copied over files to this d2 500GB drive with quad interface. Hooked up the drive via FW to my Quicksilver, works just fine under 10.4. However, when I restart in OS 9, as the finder loads, I am greeted by "This disk is unrecognizable. Do you want to format it?", with the option to erase the 500GB drive. I checked with the OS 10.4 disk utility, it is formatted as Mac OS Extended, Journaled, which should be just fine for 9. Any ideas as to what might cause this to happen?
