So basically - which of those two parts do I need to install if I'm using one of the packs you linked? I know obviously I need the ribbon board but of the two others?
MacPlus is finally finished. Upgraded to 4MB, floppy drives (internal and external) cleaned, rust removed from rear ports, internal bracket on the motherboard, and corrosion removed from the battery connectors. Also the battery door was missing so 3d printed one.
The above is a comparison between my HHKB and the new design 68 keyboard. Also you can see the holes I had to cut to accommodate the ADB cable as well as the ADB passthrough port. Wasn't perfect but not horrible by any means. I had to make the hole for the passthrough fairly large to accommodate the ADB end connectors I have.
Finally, with the keycaps installed:
You are also better than me at cutting things straight. The square ADB hole looks nice
I'm interested! I've been wanting to build one of these. Please send me a PM and let me know how much you'd like for a board.FYI, I have 3 extra PCB boards.
